Differences
Link to this comparison view
Both sides previous revision Previous revision
Next revision
Previous revision
documentation [2007/10/24 11:01]
admin
documentation [2016/01/25 16:35]
admin [Requirements]
Line 9: Line 9:
 ==== Requirements ==== ==== Requirements ====
-Installer requires recent versions of [[http://​www.python.org|Python]] ​([[http://​www.python.org/​ftp/​python/​2.5.1/​python-2.5.1.msi|v2.5]])+Installer requires recent versions of [[http://​www.python.org|Python]],​
-[[http://​trolltech.com/​developer/​downloads/​qt/​windows|Qt]] ​([[ftp://​ftp.trolltech.com/​qt/​source/​qt-win-opensource-4.3.1-mingw.exe|v4.3.1]]) ​and [[http://​www.riverbankcomputing.co.uk/​pyqt/​download.php|PyQt]] ​([[http://​www.riverbankcomputing.com/​Downloads/​PyQt4/​GPL/​PyQt-Py2.5-gpl-4.3.1-1.exe|v4.3]]).+[[http://​trolltech.com/​developer/​downloads/​qt/​windows|Qt]] and [[http://​www.riverbankcomputing.co.uk/​pyqt/​download.php|PyQt]].
 To run the examples, you will have to install [[http://​sourceforge.net/​project/​showfiles.php?​group_id=5988&​package_id=6035|PyOpenGL]]. This last package uses [[http://​peak.telecommunity.com/​dist/​ez_setup.py|easy_install]] tool to be installed. To run the examples, you will have to install [[http://​sourceforge.net/​project/​showfiles.php?​group_id=5988&​package_id=6035|PyOpenGL]]. This last package uses [[http://​peak.telecommunity.com/​dist/​ez_setup.py|easy_install]] tool to be installed.
Line 22: Line 22:
 # installing PyOpenGL # installing PyOpenGL
 C:​\Python25\easy_install.exe PyOpenGL</​code>​ C:​\Python25\easy_install.exe PyOpenGL</​code>​
 ==== Install ==== ==== Install ====
-You can then simply install the ''​exe''​ installer that you can find [[http://​gforge.inria.fr/​frs/​download.php/​2247/​PyQGLViewer-0.1.0-Py2.5-Qt4.2.3-QGLViewer2.2.5-1.exe|here]] ​+On windows, you may simply install the last ''​exe''​ installer that you can find [[http://​gforge.inria.fr/​frs/​?​group_id=773|here]]. However, distribution are not frequent.
 To test it, you may launch examples [Start Menu]/​Programs/​PyQGLViewer/​examples. To test it, you may launch examples [Start Menu]/​Programs/​PyQGLViewer/​examples.
-===== How to build and install ​the project from sources =====+You can look at the OpenAlea distribution of PyQGLViewer. See the [[http://​openalea.gforge.inria.fr/​|OpenAlea website]].
 +In particular for Linux (Ubuntu mainly) you can install it this way:
 +<code bash>
 +sudo add-apt-repository ppa:​christophe-pradal/​openalea
 +sudo add-apt-repository ppa:​christophe-pradal/​vplants
 +sudo apt-get install pyqglviewer
 +</​code>​
 +It will install a libQGLViewer package and PyQGLViewer. ​
 +For windows,​after download and installing easy_install. You can type
 +<code bash>
 +easy_install -f http:://​openalea.geforge.inria.fr/​pi openalea.deploy
 +alea_install pyqglviewer
 +</​code>​
 +Or use the normal installation of openalea et vplants.
 +This may changed in the future. So look at the OpenAlea documentation to have an update procedure.
 +===== How to build and install the project from sources =====
Line 40: Line 60:
 Unzip the archive on your disk. For instance Unzip the archive on your disk. For instance
-<code bash>​unzip PyQGLViewer-x-x.zip </​code>​+<code bash>​unzip PyQGLViewer-x.x.zip </​code>​
 A directory ''​PyQGLViewer/''​ should be created. A directory ''​PyQGLViewer/''​ should be created.
-This project requires a recent version of SIP (tested with 4.5.2, 4.6 and 4.7), Qt4 and PyQt4.+This project requires a recent version of SIP, Qt4 and PyQt4.
 <note important> ​ <note important> ​
-PyQt4 should be installed with its sip and development files. Binaries version provides by Riverbank ​unfortunatly ​do not include all these development files. You may have to recompile it.+PyQt4 should be installed with its sip and development files. Binaries version provides by Riverbank ​unfortunately ​do not include all these development files. You may have to recompile it.
 </​note>​ </​note>​
-=== Building ​a custom version ​of QGLViewer ===+=== Building ​ of QGLViewer ===
-To build ''​PyQGlViewer'',​ you need to build a customized version of +To build ''​PyQGlViewer'',​ you need to have libQGLViewer. ​
-libQGLViewer. ​Actually, it has been build from version 2.2.6-3. You should download a version of the sources:+It is part of most Linux distribution. On Mac, it comes with macportsOn Windows, with Cygwin.
-[[http://​artis.imag.fr/​~Gilles.Debunne/​QGLViewer/​download.html|http://​artis.imag.fr/​~Gilles.Debunne/​QGLViewer/​download.html]]+If it is not the case or if you want to use a more recent version of the lib.
 +You  will need to build it from sources.
-for linux, archive is: +You should first download a version of the sources:
-[[http://​artis.imag.fr/​Members/​Gilles.Debunne/​QGLViewer/​src/​libQGLViewer-2.2.6-3.tar.gz|http://​artis.imag.fr/​Members/​Gilles.Debunne/​QGLViewer/​src/​libQGLViewer-2.2.6-3.tar.gz]]+
-and for windows +[[http://​artis.imag.fr/​~Gilles.Debunne/​QGLViewer/​download.html|http://​artis.imag.fr/​~Gilles.Debunne/​QGLViewer/​download.html]]
-[[http://​artis.imag.fr/​Members/Gilles.Debunne/​QGLViewer/​src/​libQGLViewer-2.2.6-3.zip +
-|http://​artis.imag.fr/​Members/Gilles.Debunne/​QGLViewer/​src/​libQGLViewer-2.2.6-3.zip]]+
-<code bash>tar xvzf libQGLViewer-2.2.x-x.tar.gz </code+<code bash>tar xvzf libQGLViewer-x.x.x.tar.gz </​code>​
-A directory ''​libQGLViewer-2.2.x-x''​ should be created. You have to compile the sources it. To be compatible with SIP, +
-you first need to patch these sources.  +
-The patch file ''​libQGLViewer-2.2.x-x-py.patch''​ can been found in ''​PyQGLViewer/​src''​ dir.  +
-<note info>  +
-For info, it has been build with the following command +
-<code bash>​diff -abur libQGLViewer-2.2.x-x libQGLViewer-2.2.x-x-py > libQGLViewer-2.2.x-x-py.patch </​code>​ +
-For windows, the ''​patch''​ and ''​diff''​ tools can in the [[http://​gnuwin32.sourceforge.net/​packages.html|gnuwin32 project]] +
-</​note>​ +
-To apply this patch, you should go in the parent directory of ''​libQGLViewer-2.2.x-x''​ +
-and invoke the command +
-<code bash>​patch -p 0 -i PyQGLViewer/​src/​libQGLViewer-2.2.x-x-py.patch </​code>​ +
-<note important>​  +
-The patch file has been built on windows sources. The end of line character is different on unix systems. +
-On linux, you may thus have to convert first the patch file to unix convention with the following comand. +
-<code bash>​dos2unix libQGLViewer-2.2.x-x-py.patch </​code>​ +
-</note>+
 Source are now ready to compile. ​ Source are now ready to compile. ​
-Go into ''​libQGLViewer-2.2.x-x/​QGLViewer''​ dir +Go into ''​libQGLViewer-x.x.x/​QGLViewer''​ dir
-<code bash>cd libQGLViewer-2.2.x-x/QGLViewer+<code bash>cd libQGLViewer-x.x.x/QGLViewer
 qmake-qt4 QGLViewer.pro qmake-qt4 QGLViewer.pro
 make         # or nmake make         # or nmake
Line 102: Line 98:
 </​code>​ </​code>​
 On windows to install the lib you should copy the ''​QGLViewer2.dll''​ On windows to install the lib you should copy the ''​QGLViewer2.dll''​
-in library repository such as ''​C:\WINDOWS\system32''​+in library repository such as ''​%QTDIR%\bin''​
-To have designer plugin (required if you will used pyuic), you should go to ''​libQGLViewer-2.2.x-x/​designerPlugin''​+<code bash>​copy release\QGLViewer2.dll %QTDIR%\bin
 +copy release\QGLViewer2.lib %QTDIR%\lib
 +</​code>​
 +To have designer plugin (required if you will used pyuic), you should go to ''​libQGLViewer-x.x.x/​designerPlugin''​
 and invoke similar command and invoke similar command
 <code bash>cd ../​designerPlugin <code bash>cd ../​designerPlugin
Line 113: Line 113:
 libQGLViewer is now compiled and usable. libQGLViewer is now compiled and usable.
Line 125: Line 122:
 You should be root on linux to make it work. You can specify the  You should be root on linux to make it work. You can specify the
-source repository of ''​libQGLViewer-2.2.x-x''​ with ''​-Q''​ option.+source repository of ''​libQGLViewer-x.x.x''​ with ''​-Q''​ option.
 For instance ​ For instance ​
-<code bash>​python configure.py -Q ../​libQGLViewer-2.2.x-x </​code>​+<code bash>​python configure.py -Q ../​libQGLViewer-x.x.x </​code>​
 <​note>​ You may specify extra include and lib directories with -I and -L flags <​note>​ You may specify extra include and lib directories with -I and -L flags
-<code bash>​python configure.py -Q ../​libQGLViewer-2.2.x-x -I /​extra/​inc/​dir -L /​extra/​lib/​dir+<code bash>​python configure.py -Q ../​libQGLViewer-x.x.x -I /​extra/​inc/​dir -L /​extra/​lib/​dir
 </​code>​ </​code>​
 </​note>​ </​note>​
Line 138: Line 135:
 make install # or nmake install, you should be root make install # or nmake install, you should be root
 </​code>​ </​code>​
-You can then test the new module with all examples
-that you'll find in the directory ''​PyQGLViewer/​examples''​.
-Good luck.
Line 226: Line 218:
 === Version === === Version ===
-You can check the version of the QGLViewer with global hexadecimal value ''​QGLViewerVersion''​.+You can check the version of the QGLViewer with the global hexadecimal value ''​QGLViewerVersion''​.
 Moreover, the following convenience function gives the version as a string: Moreover, the following convenience function gives the version as a string:
 <code python>​def QGLViewerVersionString():​ <code python>​def QGLViewerVersionString():​
     """​ Return version of QGLViewer in a string format """</​code>​     """​ Return version of QGLViewer in a string format """</​code>​
 +You can also check the version of the wrappers with the global hexadecimal value ''​_ _version_ _''​
 +or the function ''​PyQGLViewerVersionString''​ for the string version.
Back to top
documentation.txt · Last modified: 2016/01/25 16:35 by admin
Valid CSS Driven by DokuWiki Valid XHTML 1.0
