Differences
Link to this comparison view
Both sides previous revision Previous revision
Next revision
Previous revision
Next revision Both sides next revision
documentation [2008/07/16 13:05]
admin
documentation [2016/01/18 17:57]
admin [Additional functions]
Line 22: Line 22:
 # installing PyOpenGL # installing PyOpenGL
 C:​\Python25\easy_install.exe PyOpenGL</​code>​ C:​\Python25\easy_install.exe PyOpenGL</​code>​
 ==== Install ==== ==== Install ====
-On windows, you may simply install the last ''​exe''​ installer that you can find [[http://​gforge.inria.fr/​frs/?​group_id=773|here]] ​+On windows, you may simply install the last ''​exe''​ installer that you can find [[http://​gforge.inria.fr/​frs/?​group_id=773|here]]. However, distribution are not frequent.
 To test it, you may launch examples [Start Menu]/​Programs/​PyQGLViewer/​examples. To test it, you may launch examples [Start Menu]/​Programs/​PyQGLViewer/​examples.
 +You can look at the OpenAlea distribution of PyQGLViewer. See the [[http://​openalea.gforge.inria.fr/​|OpenAlea website]].
 +In particular for Linux (Ubuntu mainly) you can install it this way:
 +<code bash>
 +sudo add-apt-repository ppa:​christophe-pradal/​openalea
 +sudo add-apt-repository ppa:​christophe-pradal/​vplants
 +sudo apt-get install pyqglviewer
 +</​code>​
 +It will install a libQGLViewer package and PyQGLViewer. ​
 +For windows,​after download and installing easy_install. You can type
 +<code bash>
 +easy_install -f http:://​openalea.geforge.inria.fr/​pi openalea.deploy
 +alea_install pyqglviewer
 +</​code>​
 +Or use the normal installation of openalea et vplants.
 +This may changed in the future. So look at the OpenAlea documentation to have an update procedure.
 ===== How to build and install the project from sources ===== ===== How to build and install the project from sources =====
Line 37: Line 60:
 Unzip the archive on your disk. For instance Unzip the archive on your disk. For instance
-<code bash>​unzip PyQGLViewer-x-x.zip </​code>​+<code bash>​unzip PyQGLViewer-x.x.zip </​code>​
 A directory ''​PyQGLViewer/''​ should be created. A directory ''​PyQGLViewer/''​ should be created.
Line 67: Line 92:
 <note info> ​ <note info> ​
 For info, it has been build with the following command For info, it has been build with the following command
-<code bash>​diff -abur libQGLViewer-x.x.libQGLViewer-x.x.x-py > libQGLViewer-x.x.x-py.patch </​code>​+<code bash>​diff -abur ../libQGLViewer-x.x.x ​> libQGLViewer-x.x.x-py.patch </​code>​
 For windows, the ''​patch''​ and ''​diff''​ tools can in the [[http://​gnuwin32.sourceforge.net/​packages.html|gnuwin32 project]] For windows, the ''​patch''​ and ''​diff''​ tools can in the [[http://​gnuwin32.sourceforge.net/​packages.html|gnuwin32 project]]
Line 75: Line 100:
 To apply this patch, you should go in the parent directory of ''​libQGLViewer-x.x.x''​ To apply this patch, you should go in the parent directory of ''​libQGLViewer-x.x.x''​
 and invoke the command and invoke the command
-<code bash>​patch -p 0 -i PyQGLViewer/​src/​libQGLViewer-x.x.x-py.patch </​code>​+<code bash>cd libQGLViewer-x.x.x
 +patch -p 0 -i ../PyQGLViewer/​src/​libQGLViewer-x.x.x-py.patch ​ </​code>​
 <note important> ​ <note important> ​
Line 83: Line 109:
 <code bash>​dos2unix libQGLViewer-x.x.x-py.patch </​code>​ <code bash>​dos2unix libQGLViewer-x.x.x-py.patch </​code>​
 +</​note>​
 +<​note> ​
 +Previous patches with lower versions than 2.3.4 where built from above repository. Thus to apply them you had to call
 +<code bash>​patch -p 0 -i PyQGLViewer/​src/​libQGLViewer-x.x.x-py.patch ​ </​code>​
 +However they were not reusable from one version to the other.
 </​note>​ </​note>​
Line 93: Line 125:
 </​code>​ </​code>​
 On windows to install the lib you should copy the ''​QGLViewer2.dll''​ On windows to install the lib you should copy the ''​QGLViewer2.dll''​
-in library repository such as ''​C:\WINDOWS\system32''​+in library repository such as ''​%QTDIR%\bin''​
-<code bash>​copy release\QGLViewer2.dll ​C:\WINDOWS\system32+<code bash>​copy release\QGLViewer2.dll ​%QTDIR%\bin
 +copy release\QGLViewer2.lib %QTDIR%\lib
 </​code>​ </​code>​
Line 212: Line 245:
 === Version === === Version ===
-You can check the version of the QGLViewer with global hexadecimal value ''​QGLViewerVersion''​.+You can check the version of the QGLViewer with the global hexadecimal value ''​QGLViewerVersion''​.
 Moreover, the following convenience function gives the version as a string: Moreover, the following convenience function gives the version as a string:
 <code python>​def QGLViewerVersionString():​ <code python>​def QGLViewerVersionString():​
     """​ Return version of QGLViewer in a string format """</​code>​     """​ Return version of QGLViewer in a string format """</​code>​
 +You can also check the version of the wrappers with the global hexadecimal value ''​__version__''​
 +or the function ''​PyQGLViewerVersionString''​ for the string version.
Back to top
documentation.txt · Last modified: 2016/01/25 16:35 by admin
Valid CSS Driven by DokuWiki Valid XHTML 1.0
