Differences
Link to this comparison view
Both sides previous revision Previous revision
Next revision
Previous revision
Last revision Both sides next revision
documentation [2011/03/31 12:15]
admin
documentation [2016/01/18 17:58]
admin [Additional functions]
Line 22: Line 22:
 # installing PyOpenGL # installing PyOpenGL
 C:​\Python25\easy_install.exe PyOpenGL</​code>​ C:​\Python25\easy_install.exe PyOpenGL</​code>​
Line 42: Line 43:
 It will install a libQGLViewer package and PyQGLViewer. ​ It will install a libQGLViewer package and PyQGLViewer. ​
-This may changed in the future. So look at the OpenAlea documentation to have an update procedure.
 For windows,​after download and installing easy_install. You can type For windows,​after download and installing easy_install. You can type
Line 51: Line 50:
 </​code>​ </​code>​
 Or use the normal installation of openalea et vplants. Or use the normal installation of openalea et vplants.
 +This may changed in the future. So look at the OpenAlea documentation to have an update procedure.
 ===== How to build and install the project from sources ===== ===== How to build and install the project from sources =====
Line 62: Line 63:
 A directory ''​PyQGLViewer/''​ should be created. A directory ''​PyQGLViewer/''​ should be created.
Line 123: Line 125:
 </​code>​ </​code>​
 On windows to install the lib you should copy the ''​QGLViewer2.dll''​ On windows to install the lib you should copy the ''​QGLViewer2.dll''​
-in library repository such as ''​C:\WINDOWS\system32''​+in library repository such as ''​%QTDIR%\bin''​
-<code bash>​copy release\QGLViewer2.dll ​C:\WINDOWS\system32+<code bash>​copy release\QGLViewer2.dll ​%QTDIR%\bin
 +copy release\QGLViewer2.lib %QTDIR%\lib
 </​code>​ </​code>​
Line 242: Line 245:
 === Version === === Version ===
-You can check the version of the QGLViewer with global hexadecimal value ''​QGLViewerVersion''​.+You can check the version of the QGLViewer with the global hexadecimal value ''​QGLViewerVersion''​.
 Moreover, the following convenience function gives the version as a string: Moreover, the following convenience function gives the version as a string:
 <code python>​def QGLViewerVersionString():​ <code python>​def QGLViewerVersionString():​
     """​ Return version of QGLViewer in a string format """</​code>​     """​ Return version of QGLViewer in a string format """</​code>​
 +You can also check the version of the wrappers with the global hexadecimal value ''​_ _version_ _''​
 +or the function ''​PyQGLViewerVersionString''​ for the string version.
Back to top
documentation.txt · Last modified: 2016/01/25 16:35 by admin
Valid CSS Driven by DokuWiki Valid XHTML 1.0
