Differences
Link to this comparison view
Both sides previous revision Previous revision
documentation [2016/01/18 17:58]
admin [Additional functions]
documentation [2016/01/25 16:35] (current)
admin [Requirements]
Line 72: Line 72:
 <note important> ​ <note important> ​
-PyQt4 should be installed with its sip and development files. Binaries version provides by Riverbank ​unfortunatly ​do not include all these development files. You may have to recompile it.+PyQt4 should be installed with its sip and development files. Binaries version provides by Riverbank ​unfortunately ​do not include all these development files. You may have to recompile it.
 </​note>​ </​note>​
-=== Building ​a custom version ​of QGLViewer ===+=== Building ​ of QGLViewer ===
-To build ''​PyQGlViewer'',​ you need to build customized ​version of +To build ''​PyQGlViewer'',​ you need to have libQGLViewer.
-libQGLViewer. You should first download a version of the sources:+It is part of most Linux distribution. On Mac, it comes with macports. On Windows, with Cygwin.
 +If it is not the case or if you want to use more recent ​version of the lib.
 +You  will need to build it from sources.
 +You should first download a version of the sources:
 [[http://​artis.imag.fr/​~Gilles.Debunne/​QGLViewer/​download.html|http://​artis.imag.fr/​~Gilles.Debunne/​QGLViewer/​download.html]] [[http://​artis.imag.fr/​~Gilles.Debunne/​QGLViewer/​download.html|http://​artis.imag.fr/​~Gilles.Debunne/​QGLViewer/​download.html]]
Line 84: Line 89:
 Unzip the archive on your disk. For instance Unzip the archive on your disk. For instance
 <code bash>tar xvzf libQGLViewer-x.x.x.tar.gz </​code>​ <code bash>tar xvzf libQGLViewer-x.x.x.tar.gz </​code>​
-A directory ''​libQGLViewer-x.x.x''​ should be created. You have to compile the sources it. To be compatible with SIP,
-you first need to patch these sources. ​
-The patch file ''​libQGLViewer-x.x.x-py.patch''​ can been found in ''​PyQGLViewer/​src''​ dir.
-<note info> ​
-For info, it has been build with the following command
-<code bash>​diff -abur ../​libQGLViewer-x.x.x . > libQGLViewer-x.x.x-py.patch </​code>​
-For windows, the ''​patch''​ and ''​diff''​ tools can in the [[http://​gnuwin32.sourceforge.net/​packages.html|gnuwin32 project]]
-</​note>​
-To apply this patch, you should go in the parent directory of ''​libQGLViewer-x.x.x''​
-and invoke the command
-<code bash>cd libQGLViewer-x.x.x
-patch -p 0 -i ../​PyQGLViewer/​src/​libQGLViewer-x.x.x-py.patch ​ </​code>​
-<note important> ​
-The patch file has been built on windows sources. The end of line character is different on unix systems.
-On linux, you may thus have to convert first the patch file to unix convention with the following comand.
-<code bash>​dos2unix libQGLViewer-x.x.x-py.patch </​code>​
-</​note>​
-<​note> ​
-Previous patches with lower versions than 2.3.4 where built from above repository. Thus to apply them you had to call
-<code bash>​patch -p 0 -i PyQGLViewer/​src/​libQGLViewer-x.x.x-py.patch ​ </​code>​
-However they were not reusable from one version to the other.
-</​note>​
 Source are now ready to compile. ​ Source are now ready to compile. ​
Back to top
documentation.1453136326.txt.gz · Last modified: 2016/01/18 17:58 by admin
Valid CSS Driven by DokuWiki Valid XHTML 1.0
