Differences
Link to this comparison view
Both sides previous revision Previous revision
Next revision
Previous revision
examples [2007/10/24 11:17]
admin
examples [2007/10/24 11:29]
admin
Line 88: Line 88:
 {{simpleviewer.png|}} {{simpleviewer.png|}}
 ===== Texture 3D example ===== ===== Texture 3D example =====
Line 97: Line 98:
 In the ''​draw''​ method, a dynamic pyramid is drawn using texture 3D. In the ''​draw''​ method, a dynamic pyramid is drawn using texture 3D.
-The ''​animate''​ method ​update ​the coordinates of the pyramid.+The ''​animate''​ method ​updates ​the coordinates of the pyramid.
Line 106: Line 109:
 from PyQGLViewer import * from PyQGLViewer import *
 import OpenGL.GL as ogl import OpenGL.GL as ogl
 +import math
 helpstr = """<​h2>​T e x t u r e 3 D</​h2>​ helpstr = """<​h2>​T e x t u r e 3 D</​h2>​
Line 125: Line 129:
         # texture coordinates are always specified before the vertex they apply to.         # texture coordinates are always specified before the vertex they apply to.
         for x in range(4):         for x in range(4):
-            ogl.glTexCoord3d(self.center[0], self.center[1],​ self.center[2]+            ogl.glTexCoord3dv(self.center)
-            ogl.glVertex3d(self.center[0], self.center[1],​ self.center[2])+            ogl.glVertex3dv(self.center)
-            ogl.glTexCoord3d(self.base[x][0], self.base[x][1],​ self.base[x][2]) +            ogl.glTexCoord3dv(self.base[x])
-            ogl.glVertex3d(self.base[x][0], self.base[x][1],​ self.base[x][2])+            ogl.glVertex3dv(self.base[x])
-            ogl.glTexCoord3d(self.base[(x+1)%4][0], self.base[(x+1)%4][1],​ self.base[(x+1)%4][2]) +            ogl.glTexCoord3dv(self.base[(x+1)%4])
-            ogl.glVertex3d(self.base[(x+1)%4][0], self.base[(x+1)%4][1],​ self.base[(x+1)%4][2])+            ogl.glVertex3dv(self.base[(x+1)%4])
         ogl.glEnd()         ogl.glEnd()
     def init(self):     def init(self):
Line 162: Line 166:
     main()     main()
 </​code>​ </​code>​
 +==== Result ====
 +{{texture3d.jpg?​300|}}
Back to top
examples.txt · Last modified: 2007/10/24 11:29 by admin
Valid CSS Driven by DokuWiki Valid XHTML 1.0
