Differences
Link to this comparison view
Both sides previous revision Previous revision
Next revision Both sides next revision
examples [2007/10/24 11:21]
admin
examples [2007/10/24 11:22]
admin
Line 88: Line 88:
 {{simpleviewer.png|}} {{simpleviewer.png|}}
 ===== Texture 3D example ===== ===== Texture 3D example =====
Line 97: Line 98:
 In the ''​draw''​ method, a dynamic pyramid is drawn using texture 3D. In the ''​draw''​ method, a dynamic pyramid is drawn using texture 3D.
-The ''​animate''​ method ​update ​the coordinates of the pyramid.+The ''​animate''​ method ​updates ​the coordinates of the pyramid.
Back to top
examples.txt ยท Last modified: 2007/10/24 11:29 by admin
Valid CSS Driven by DokuWiki Valid XHTML 1.0
